bcsparks4 said:Where does it state that "all AFCI's have 30 ma. GFCI's built in."
ohm said:Let me guess...someone used an electric screwdriver to tighten the NM connector. Good case to use the hit-lok nm connectors (cheaper too).
Also, I consider a romex staples' only function in life is to hold the nm in the wall long enough for the rocker to close it up. That extra wack with the hammer can cost you big time. If an inexperienced helper is on the job the cushioned staples may be worth it.
Glad you found it. How long did it take?
pbeasley said:Just thought I'd let everyone know it looks like this was a NM connector that was over tightened. .
electricmanscott said:Could you direct me to this tester? :-?
