electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
Year/Month/Day Time based on 24 hour (14:53 = 2:53 PM) Eastern Standard Time
2008/Dec/03
Got it! Now....why?
2008/Dec/03
Got it! Now....why?![]()
081203-1950 EST
electricmanscott:
This provides a monotonic number with respect to date and time. Something in the body of the text to use for search purposes, or just identification.
I create filenames at times using the same method. So if I create a CNC (computer numerical control) program file with a name like B457_D23-081101-2303 and later modify this and change the date and time portion to 081203-0900, then on doing an alphanumeric sort the files will be in time order.
With this site's search function I can enter 081202-**** and find my yesterday's posts. Or 0811**-**** and find last months. Unfortunately Google does not allow wildcard character substitution. But under Google you can use * for a word.
Line and loads isolated ground connected to the ground bus in the panel
Megger the energized conductor to neutral
Megger the energized conductor to ground
Megger the neutral to ground.
1000 VDC test voltage,
Check all loads is the AFCI tripping with loads connected of without loads connected?
