pnilsson2000
- Oregon
I have an older house that has 2 wire outlets thru-out and want to upgrade to 3 wire outlets.
my understanding is that this can be done using a gfci breaker or outlet and labeling the out outlets as gfci protected. well a couple of the rooms are bedrooms and I understand the new code requires afci's in the bedrooms. my question is should I stay with gfci plan or make the bedrooms afci. and if I changed the bedrooms to afci would i still be able to upgrade to 3 wire outlets even if I only two wires at the outlet. it would be very diffucult to add grounds to these outlets. any help would be appericiated
