- Wisconsin
- PE (Retired) - Power Systems
Then make appliances that can be put into homes built before 2017.It's 2026,
Things just need to work.
Jap>
Jap>
I have no problem with GFCIs, just the expansion into places where they aren't needed and equipment that isn't compatible making for nuisance tripping. Like the old saying goes "if it aint broke don't fix it". Yes, they have been reliable for 50 years, so make equipment work with them not the other way around.They did a good job with GFCIs, their parameters lasted some 50 years, before they needed tweaking.
50 years ago we did not have the plethora of electronic motor controllers and power supplies, with their harmonics, that we have now. I can understand that some of our protection parameters may need to be tweaked. Kind of like we did with conductor ratings as insulation got better.Yes, they have been reliable for 50 years, so make equipment work with them not the other way around.
The appliances are fine. The problem is expanding GFCI protection where it's not needed and the forced adoption of AFCI that doesn't work.If the appliances are the issue, then why not make appliances that work with the electrical system that are required to be installed?
Jap>
Kinda sort of. I can think of one place where GFCI protection is needed and that is with pool pumps. If a pool pump won't play nice with existing GFCIs it should be up to the manufacturer to redesign the pump so it does, not expect the GFCIs to be redesigned. It's a lot easier to put power line filters in the back of a pump motor than it is in a little plastic GFCI housing.The appliances are fine. The problem is expanding GFCI protection where it's not needed
50 years ago we didn't think GFCI'S were reliableYes, they have been reliable for 50 years, so make equipment work with them not the other way around.
But they were, well maybe not some brands of receptacles, but overall we learned to live with them.50 years ago we didn't think GFCI'S were reliable
If you think about the state of technology back then it makes you wonder how something like that could be made in a small package. 50 years ago we had the brick phone. As far as GFCIs are concerned, the design could only be rudimentary with what components were available. So, I could see the skepticism which might have even been founded.50 years ago we didn't think GFCI'S were reliable
I've moved into full time commercial work since 2018, before that the shop I worked for did large custom homes, commercial and service work in both camps. Early on in the adoption of AFCIs I gathered a reputation as the guy who could excise the demons out of nuisance tripping AFCIs. I would go on a service call and find a neutral to ground fault or a crossed neutral on the circuit every time. I was among the crowd who said anybody who had problems with AFCIs needed to get their act together and stop blaming the breaker when it was lousy wiring practices that were the problem.One thing I have noticed about this forum is you all really hate AFCI's.
The other thing I notice is the long time posters whom are clearly long time practicing master electricians, who do residential, like @hbiss or @LarryFine to name a few rarely if ever seem to be the ones with a AFCI problem on their own electrical work.
