Folks, I need some help with my thinking. Consider the 2005 NEC. AFCIs are required for bedrooms in dwellings. Certain multistory student housing facilities consist of apartments, each of which has a living room, bedroom(s) and toilet facilities but no cooking facilities. Therefore, by the NEC definition these are not dwellings. Therefore, if I read the Code correctly, these bedrooms need not be protected by AFCIs. Is this correct? If yes, why are these types of housing facilities assumed to be less susceptible to arc faults, do arc faults occur only in kitchens? Shouldn't the students' bedrooms be equally protected? What am I missing here?
(I know that the 2008 NEC broadens the AFCI use requirement, but then again maybe not, considering the resistance that that requirement is running into.)
Many thanks for your input.
Heinz R.
Heinz R.
