Doing a major remodel the ahj uses the 2000 nec. The arch. states in remarks bedrooms to be arc fault prot.
Used the same page for carpentry, cabinetry, electrical, plumbing this is a 4 room major gut job knocked down 6 load supporting walls used engineer for wall support.
So here I go home is 150amp exterior main fed via a no longer used fuze panel gutted out and connected to a square D QO style surface mount panel. Roughing as I go along when I finish a room I power it up and check for operation shorts etc. all work okay getting close to rough inspection time to remove the stnd cbs for the 2 bedrooms and install the afcis. They hold okay but the minute you attempt to test any load they trip. Installed exactly per manufactures specs with the install sheet in front of me it holds power with no useage. If I attempt to put a 40watt test light ( Pigtail tester) from power to neutral not ground but neutral pop goes the afci. I took it out and installed a 15amp. It holds no problem. Powered up 1 cieling fan 1 smoke detector 4 outlets with vac, radio, tv plugged in holds all. Install a second afci it pops every time.
History both bedrooms were pulled in as a 14/3 circuit with a shared neutral. My setup is the 14/3 is split in a 1900 box with seperate feeds to each bedroom. I have the same problem on either bedroom.
I am open to suggestions tomorrow I am gonna do new home runs outside the walls cielings etc and see if they each hold on seperate circuits, But I have little to no experience with afci. I installed them with ground wire to large screw and pigtail attached to ground bus. Line feed to small attachment point per man instructions. Keeps popping any ideas teammates?
