ChasM
- North Texas
- Retired. Electrical System engineer/simulator architect
This may be a stupid question. I have found that the AI apps are notoriously incorrect at calculating the correct conductor size based on type of conductor, voltage drop, ampacity, load current, distance of run, temperature, power factor, and single/three phase. I have found that none of their calculated conductor sizes compares even approximately to the values given in 2020 NEC table 331..16 or Chapter 9, table 8. It appears i will develop my own spread sheet based on fundamentals, i.e., V=IxR and various derivatives. I had hoped AI might save time, but the effort in answer verification takes too long.
Are there any reliable trustworthy apps out there which do a good job at calculating conductor size? When will an AI app be trained on the NEC code?
