our power decided at last minute to change the location of our meter loop and service closer to there utility pole. so instead of being 410' away from utlity pole. now the service will be 40' away from utility pole. which will be lot closer. our local inspector said to check the value in fault calculations if it changed we need to resubmit those affected pages to building dept. Everything else stays the same. but I noticed the values in caluculation dont match as far as fault #1 not being 115' its more like 410' +/-. #2 and # 3 alot longer also. My question besides the error in length, how do they get these values in first place?
