zam
- New York, NY
I have a situation where the electrical distribution is as follows: (Utility company's service send box) connected to (Switchboard, with about 12 disconnect switches). One disconnect switch from the switchboard will be feeding a new CT cabinet/disconnect switch. There is no transformer between the switchboard's disconnect switch and the new CT cabinet/disconnect switch. My question is as follows:
If the AIC rating of the switchboard is 85 kAIC, is the AIC rating of the new CT cabinet/disconnect switch (the AIC of the new fuses) also 85 kAIC?
OR
Will it be a different value based on short circuit calculations involving parameters like distance between the equipment, wire size between the equipment, L-L voltage, L-N voltage, etc?
Thank you.
OR
Thank you.
