olly
- Berthoud, Colorado
- Master Electrician
New condensing unit and A/C coil in the furnace. The furnace is up in an attic.
At the furnace, the the HVAC tech said he needs an outlet mounted for a pump. I assume this is for a condensation pump. Can the power for this outlet be wired from the furnace circuit. Does the outlet need to be a GFCI does the circuit now need to be AFCI?
