SouthgateMike
- Southgate, Michigan, U.S.
I was called out to take care of an update required before selling a house. I used to be a duplex so it had a double meter socket, easy enough upgrade, but the air conditioner was fed from the bottom of the meter socket, I'm assuming because the panel didn't have any existing spaces and the QO tandem breakers are more expensive than the $25 Eaton disconnect they used. The inspector said nothing about the way the AC was run in the paperwork just to update the meter socket and install proper grounding. Is it assumed that I will update the way the AC is fed when I put the new meter socket in? Just trying to bid the job properly, with parts labor and permits I am at $600, that's before the AC feed fix.
