Our company uses a constant current high voltage airport lighting system for our street lights. the lights ar in a series loop. the source transformer feeds one terminal of the first lights step down transformer using direct burial high voltage cable. The other terminal feeds one terminal of the next light. it continues that way until it returns to the source trans former. The original installer drove and connected a ground rod next to each metal pole. There is no equipment ground following along with the feeder cable to bond each pole. It is my opinion, that if somehow, the feeder touched the the pole, the pole , the ground rod and the soil surrounding it would be energized. (about 2400 volts). am I missing something??
