Al Cables vs Cu Cables Comparison - Technical and Economical
Joao
portugal
engineer
Do you have some data that you can share for EHV, HV. MV and LV cables.
In my opinion as GENERAL the cost will be more less the same as Cu or Al, since the supply cost is less but erection is higher. So more less will be same same.
I believe everything in EHV and HV is predominantly overhead aluminum.
Most of this forums member are not involved in utility transmission system design. You could always ask on a forum like engr-tips.com which has many worldwide participants.
