publicgood
- WI, USA
Below is the requirement. Does someone have an example of the product needed to terminate on compression lug or adapter at breakers and MLO panels?
- Aluminum conductors, sizes #4/0 AWG and larger, with the following conditions:
- Feeders only – no aluminum conductors for branch circuits.
- Aluminum alloy conductors shall be compact stranded conductors.
- Aluminum conductors shall terminate on a compression lug or compression adapter.
- Oxide-inhibiting joint compound must be applied on the aluminum conductor during termination.
- No copper-to-aluminum transitions permitted.
