RustyShackleford
- NC
- electrical engineer
Another issue is space in the panel - for wire bending, add'l ground bar, and such. Check this screen-grab from the Siemens catalog. Note for the 30-space/48-circuit boxes, the "outside" version is 5" taller, whereas the "inside" versions fits 10 more "spaces" (5" vertically) into the same 30" height as the older-generation 20-space/40-circuit boxes. ( I'd be tempted to use the outside box even if this were an indoor situation).
Also tempted to put the new box "upside-down" so the ground bars are close to where the branch-circuit conductors enter. Assuming there are code-compliant ways to transition from the 2" or 2-1/2" PVC conduit to the hub cutout at the breaker end of the panel.
