OK....Here's the final chapter. After examining the H745ICAT I sent to Cooper, engineers have determined that a manufacturing line error caused the fault in the can. The lampholder was installed 90 degrees out of the alignment that the specs called for thus creating the neutral to ground short that was the culprit here. The fix is to remove the 8-32 screw that holds the lampholder to the mounting bracket, rotate the lampholder 1/4 turn and reinstall the screw. The short will then be eliminated. The most frustrating part of this ordeal was simply getting to the right person that understood the problem and not some administative assistant that didn't have a clue what I was talking about. I'll bet I told my story 10 times before I finally had success. They are going to reimburse me for the cost of the air freight, my troubleshooting time and the modification time. The only remaining mystery is......how many of these cans are deployed and in use without the arc fault protection that brought this issue to the surface?
