augie47 Moderator Staff member Location Tennessee Occupation State Electrical Inspector (Retired) Apr 8, 2021 #1 Anyone have input on aluminum EMT...?? Any problems with steel or die cast fittings when used with aluminum ??
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Apr 8, 2021 #2 I've only heard of aluminum rigid.
augie47 Moderator Staff member Location Tennessee Occupation State Electrical Inspector (Retired) Apr 8, 2021 #3 https://www.americanconduit.com/products/aluminum-electrical-metallic-tubing-emt.html
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Apr 8, 2021 #4 Bridgeport does have a list of their fittings that are listed for aluminum EMT. I would assume that other manufacturer's may have something similar. https://www.bptfittings.com/wp-content/uploads/2013/06/BPT-FITTINGS-LISTING-for-Aluminum-EMT.pdf
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Apr 8, 2021 #5 augie47 said: https://www.americanconduit.com/products/aluminum-electrical-metallic-tubing-emt.html Click to expand...
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Apr 8, 2021 #6 infinity said: Bridgeport does have a list of their fittings that are listed for aluminum EMT. I would assume that other manufacturer's may have something similar. https://www.bptfittings.com/wp-content/uploads/2013/06/BPT-FITTINGS-LISTING-for-Aluminum-EMT.pdf Click to expand... The product brochure says it's compatible with steel and cast fittings, and mentions an NEC atricle. https://www.americanconduit.com/wp-content/uploads/PullEase-8-page-Booklet_Mar_2021.pdf
kwired Electron manager Location NE Nebraska Occupation EC Apr 8, 2021 #7 Does ENT take about as much physical abuse? Bet sch40 PVC takes as much if not more physical abuse, presuming similar wall thickness as steel EMT. Curious as to how well it bends as well. Bet you don't "undo" mistakes in bending as easily as you can with steel EMT
