LarryFine
- Henrico County, VA
- Electrical Contractor
Imagine that.rcwilson said:When I worked for an aluminum company we required all aluminum conduit.
I wouldnt use aluminum underground or encased in concrete, thats what PVC is for....Mike01 said:Does standard rigid aluminum conduit come with corrosion protection or would this be an additional requirement? Only for when the conduit passes thru concrete floor / wall penetrations because of the reaction with the aluminum and concrete. I guess you could also provide a link-seal of some type between the conduit and the concrete also.
wireman said:Maybe "stretch" is the wrong term, but what we noticed was that it was difficult to match bends even from the same bundle of pipe. We had some expert conduit men and everyone had trouble with it.
Mike01 said:Just curious what others opinions are, Rigid Aluminum conduit in leau of Rigid Steel? What are the advantages / disadvantages from what I can find Aluminum is lighter and therefore easier to install, however does not have the wall thickness or a Rigid Steel Conduit. Just curious there is a project where the contractor has suggested aluminum conduit in leau of rigid as a potential cost savings other than the wall thickness is there any other advantage / disadvantages?
I find that true of any conduit... even swings with the temperature. But yes, aluminum has a wider range than steel... but it is also easier to "fix" ... :grin:K8MHZ said:Al is a bear to run because the hardness of the conduit varies so much which makes each piece spring back differently.
weressl said:Since the extrusion process offers a smoother surface than the GRS, pulling conductors through it should be easier.
