The only problem I can see is that the average homeowner has NO idea what they are doing while taking on home improvement jobs. Electrical Especially... If a home was originally built with AL, and a homeowner was replacing some form of Electrical equipment, light fixtures, rcpts etc. and replaced the equipment with anything that had Copper terms, they could easily burn down the home. I attended a presentation that was put on by a research rep for ALCAN, a large aluminum producer and distributer, his recomendation was that aluminun should be primarily used in Commercial/Industrial applications. As for the wire itself with new processes they were able to produce a wire called STABILOY, which is a wire that is so flexible and also sturdy, that I had a tough time bending it to its breaking point. It took substantially longer than that of the same size solid copper conducter. Though the wire sizes maybe larger due to lower ampacitys, a 200 kcmil stabiloy conducter is in fact easier to terminate than a 100 kcmil copper conducter...
