Marty Funkhauser
- The other side of aluminum
- electrical apprentice
If you come across an aluminum splice of lets say 5 #12s that you need to take apart for troubleshooting. The connection has an old wire nut on it currently that was probably installed in 1970s when the splice was made. You take the connector off separate the wires and do your testing. Now its time to put the splice back together what do you do?? The Ideal purple wire nuts say on the packaging not to use on aluminum to aluminum connections. Split bolts are usually rated for 2 or 3 wires. The standard wire nut in your pouch is for copper only. Multi tap connectors take up a lot of space in lets say a two gang plastic box. Now what
