electricalperson
- massachusetts
is aluminum wiring actually a problem or is it just the person installing it the problem?
I cannot tell a lie; it was I. :smile:Whoever said, tighting all the screws was correct.
Except for this:One screw was a full 2 turns loose. But strangely, it showed no outward signs of overheating or anything wrong.
I noticed that the light switches in the greatroom ... has a wallplate that gets noticably warm to the touch when the lights have been own for about 30 minutes... Hmmm, a warning sign.
Larry,Being softer, and having a larger coefficient of expansion, than the terminal components, the aluminum flattens under the screwhead from heat, and when it cools, is slightly looser than before.
The next current warms it up more, it expands and flattens more, and gets looser still. It's cycling of power, rather than steady current, that causes aluminum wires to get loose under screwheads.
Actually the screw does not loosen. When the conductor expands it puts pressure on the screw and that causes "cold flow" on the conductor and flattens it out somewhat. This flattened wire does not change back to round wire when it cools and that results in a very small space being created between the screw and the conductor. Over time this space gets larger and you can turn the screw making it appear that the screw loosened when in fact it did not...the wire got smaller.That sounds illogical
FACT:
1. Aluminum expands at a different rate than copper.
2. Aluminum expands at a different rate than the screws and backplates of outlets designed for copper wire.
3. The different rate of expansion causes the screw to loosen eventually through repeated power on/off cycles.
I thought I said that.Actually the screw does not loosen.
So, one could conclude that air and metal expand at the same rate. :grin:If you have a 1cm diameter metal rod of the same metal, if heated identically to the plate, it will expand in diameter at the same rate as the hole.
***THREAD JACK***
How's this, this is where I went today.....
The coating was generally a zinc layer to isolate the composition rubber insulation from direct contact to the copper. The copper would degrade the insulation.Always wondered why they made tinned copper wire anyways..anyone got an "idear"?
Another fine example of why I don't like the idea of panels in bedrooms..How would you like to have THAT happening while you were sleeping?
Back on topic, I have only once run into an aluminum-wired house.
I heard that if you have a metal plate that expands when heated, and this plate has a 1cm circular hole in it, and you heat it evenly, the metal will plate will expand in all outward directions, but the diameter of the hole will increase.
About the same as I would like that in my basement, kitchen or utility room. :grin:
Seriously I don't see the difference if I am asleep.
The home I lived in from 12 to 18 was all AL NM, back stabbed into the devices and protected by an FPE 'Stab-Loc' panel. A true safety trifecta. :grin:
The refrigerator would kick on and the TV would dim out for a moment. :roll:
This idear is commonly used when fitting "press fit" items. They even make little ovens for bearings. =) Heat it up, "slide" it on, let 'er cool.
