Most terminals are suitable for use only with copper wire. Where aluminum or copper-clad aluminum wire can or shall be used (some crimp terminals may be Listed only for aluminum wire), there is marking to indicate this. Such marking is required to be independent of any marking on terminal connectors, such as on a wiring diagram or other visible location. The marking may be in an abbreviated form, such as "AL-CU."
Copper Pigtail Leads ? Copper pigtail leads may be used with aluminum or copper-clad aluminum supply wires in dry locations if 1) the splicing devices are Listed for use in joining copper to aluminum, 2) there is sufficient wiring space, and 3) the means provided for connecting the wiring system are acceptable for the wire size used.
Wiring Devices ? Supply terminals of 15 A and 20 A switches and receptacles not marked "CO/ALR" are for use with copper and copper-clad aluminum conductors only. Terminals marked "CO/ALR" are for use with aluminum, copper and copper-clad aluminum conductors.
Screwless pressure terminal connectors of the conductor push-in type are for use only with copper and copper-clad aluminum conductors, both solid and stranded, unless otherwise limited by marking.
Terminals of switches and receptacles rated 30 A and above not marked "AL/CU" are for use with copper conductors only. Terminals of switches rated 30 A and above marked "AL/CU" are for use with aluminum, copper and copper-clad aluminum conductors.
Wire Connectors ? Combinations of dissimilar conductors in terminal or splicing connectors are acceptable only in dry locations and when the connectors are identified as suitable for such intermixing. See also the information under Wire Connectors and Soldering Lugs
