GG
- Ft.Worth, T.X.
Source - Ray C. Mullin, Electrical Wiring Residential, 2005, page 559. Mr. Mullin states that "most circuit breakers are ambient temperature compensated. This means that the tripping point of the breaker is not affected by an increase in the surrounding temperature. An ambient-compensated breaker has 2 elements. One element heats up due to the current passing through it and the heat in the surrounding area. the other element heats up because of surrounding air only. The actions of these elements oppose each other. Thus, as the tripping element tends to lower its tripping point because of external heat, the 2nd element opposes the tripping element and stabilizes the tripping point. As a result, the current through the tripping element is the only factor that causes the element to open the circuit." Is this true, I have never heard of a ambient temperature compensated breaker
