Why would you? What's the biggie? The receptacle should stick out, If it dosen't you have screwed tit in too tightly.KJay said:I?ve also noticed this with the resi TR receptacles. They stick out more from the wall plates, even with the foam plate gaskets installed.
It seems that the face is thicker than the standard receptacles to allow for the TR mechanism. It appears that the solution may be either a thicker wall plate or some sort of spacer between the plate and the receptacle.
At the moment, still an ?unresolved issue?, but I haven?t had any customer complaints about this?yet.
