Ampacity loading of cable
Designer69
If I have a 60 Amp control panel, should the power feeder be loaded to no more than 80% (so run a 75A cable) or can the feeder be loaded to 100% (run 60A cable)? assuming all required derating does not apply.
thank you
infinity
New Jersey
Journeyman Electrician
How long will the maximum load of 60 amps be running? Generally the 80% factor is applied to loads that will operate at maximum ampacity for 3 or more hours.
