shortcircuit2
- South of Bawstin
What is ampacity rating of #12 AWG Copper with THWN-2 rated insulation at 60 Degrees Celsius?
Should the correction factors in table 310.15(B)(1) be used?
Using ampacity of #12 THWN-2 from Table 310.16...
Example: 30amps x .71= 21.3amps
What is ampacity rating of #12 AWG Copper with THWN rated insulation at 60 Degrees Celsius?
Using the correction factors in table 310.15(B)(1)
Using ampacity of THWN from Table 310.16...
Example: 25amps x .58=14.5amps
(wet location application) 2020 NEC
