robrobertson
I have a building that has 3ph, 120/240v system. This comes for the power company with no transformer so we use the power as is. Phase A has 6.4 amps,(Total Harmonic Distortion) THD voltage 3.7%, THD amperage 17.2%,(Crest Factor) CF 1.55. Phase B 93.6amps, THD voltage 5.2%, THD amperage 19.1%, CF 1.45. Phase C 80.3 amps, THD voltage 4.8%, THD amperage 12.8%, CF 1.46. Neutral to ground voltage is .02 volts, the amperage on the service is 5.2 amps and it is bonded to the water pipe with a ground rod. The question is where does all of all of the amperage on the ground come from? The building has about 150 computers, faxes, copiers, etc in the building so there is alot of non-linear load on the building, some computers are having problems and I think this might be some of it. Does anyone have any ideas??
