cschmid
- Northern cold country
dereckbc said:Mike maybe or maybe not. I don't think we should be telling a non-electrical professional if it is or not.
What if you were to measure the Service grounded conductor and it had 90 -amps, and the pipe was 9-amps? Is it a problem?
Now what if you measured say 10 amps on the service and 9 on the water pipe? Keep the answer to yourself, it is to make a point I think you and most understand.
Now there is a statement I can agree with..Here is a classic example of a non electrician making a diagnosis and getting a home owner upset potentially over nothing..now we end up with a legal hassle when the HO sues the HI for bad info because the HI does not want to pay the bill..If an Electrician was called to make the inspection in the first place..all of the describe circumstances could be avoided..
So is it OK for HI's to really be doing electrical inspections..so why do you not fight for you piece of the pie..
Yet I do disagree with the use of the water main as a GE I believe we cause more problems then we save..In this case it has become a GEC..If the power company maintained the GEC at ahigher level back to the transformer..we should not see the water main as a GEC as it is suppose to be a supplemental GE not a GEC..then the water pipe should not carry the unbalanced load..
Open mouth insert foot..:grin:
