Jim W in Tampa
- Tampa Florida
This looks like a job where the fix would be easier than writing a tag. That #6 would fit under lug and saved time and a split bolt. Hackers can always make an easy job hard and more costly.
So a stranded conductor (smaller than the white, like a #8) going from the kearney to the bar would have been ok?For a start,
Parallel neutral conductors smaller than 1/0
3 conductors in the split bolt
Then you go from 21 wires under the kearney to 38 (or 9 to 14 depending on the stranding).Yep.![]()
Then you go from 21 wires under the kearney to 38 (or 9 to 14 depending on the stranding)...........
Not making a conductor argument but a mechanical observation. Eventually it comes down to how many things are being crushed together in the connector. What makes one bundling superior to another? Maybe just what was actually tested but I could see a reason to test more configurations and see no reason why some non-listed configurations would be inferior.No. I go from 3 to 2. The strands are not individual conductors. They are strands in a conductor. No matter how many strands there are, it is still ONE conductor.
If you want to make the argument that they are individual conductors, then every stranded wire smaller than 1/0 would violate 310.4(A).
