Welcome to the zoo! :smile:My exam prep book says this is true? But there is no explanation? Can anyone help?
Um, don't agree.But true ungrounded systems don't have a neutral
Conventional three phase systems, delta or wye configured, have a circular voltage relationship. After all, the generated emf is a result of rotating windings in a magnetic field. Given the preceding, plot the three voltage vectors of a either wye or delta or both. The neutral will always be at the center of a circle which intersects the three voltage points. Just the nature of the beast.My exam prep book says this is true? But there is no explanation? Can anyone help?
Um, don't agree.
A star (Y) winding has a neutral point. It is still a neutral point whether or not it is grounded.
Grounding and neutral are two different matters.
Um, don't agree.
Well, of course not.a star winding is a delta ?
If it is truly delta, grounded or otherwise, there is no neutral.My exam prep book says this is true? But there is no explanation? Can anyone help?
I was simply addressing the point made by nunu161 that ungrounded systems don't have a neutral.
I was disagreeing with that point.
It is perfectly possible for an ungrounded system to have a neutral.
I have seen a few posts in this forum where "ground" and "neutral" tend to be used interchangeably. I just happen to think that it is important to have clarity in the distinction between the two.
we were talking abut delta systems not wyes
The neutral doesn't have have to be grounded to make it a neutral. Grounded or otherwise, it would still be a neutral.A wye system has to be grounded/neutral
I did not mean to infer that you are stupid. If it came across that way, I unreservedly apologise.i'm not stupid i knew what i was talking about when speaking of a delta system.
Grounding one corner of the delta does not make it a neutral.
Well, the code requires grounding of a neutral. His point was that Mother Nature does not. Please be less sensitive.A wye system has to be grounded/neutral i'm not stupid i knew what i was talking about when speaking of a delta system.
Even though a delta transformer is ungrounded there still is a neutral point that exists in the middle of one of the phases even though it is not attached to so the statement that a ungrounded delta system contains a neutral point is true? it just may not be used?
My question would then be why would people still deal with Delta systems when you can get a lot more versatility out of a 4-wire uni-grounded or multi grounded wye system? You can get two 1? voltages from the system and it is a good system for quickly clearing line to ground faults.
