K2X
- Colorado Springs
I didn't want to hijack the other thread so I'll take it here.
So this is what I think I've learned regarding 310.16 so far. Please let me know if i have it wrong or if you can add some more info for me.
1) For small conductors I use 240.4 d for every day work so I don't have to worry about 310.16.
2) My receptacles are 60 degrees unless stated otherwise ? but for small conductors it's really a non issue because of 240.4 d ??
3) once i get out of 240.4 and go to the larger conductors i have to pay attention to the termination temp rating and the columns of 310.16. So for example if I was going to run in emt a 50 amp circuit out of a marked 75 degree panel into a marked 75 degree subpanel I would use the 75 degree column and I could run a #8 thhn. But, if I was going to run in emt a 50 amp circuit out of a 75 degree panel into an unmarked 50 amp receptacle, I would assume the receptacle to be 60 degree so i would go to T310.16 and use the 60 degree column and run a #6 thhn.
I know there is 110.14 (c) for my next hurdle but am I starting to get the hang of this?? Thanks...
