Jeff S
- St. Louis, MO
We have some upcoming systems that will be 1000V ungrounded systems using Power-One Inverters. I'm clear on the fact that we need 1 or 2KV rated PV wire where it's exposed on the roof. I'm also clear on the fact tht USE-2 isn't permitted inside a building unless it's dual rated with a rating that is smoke resistant. So my question is, Can RHW-2 (2KV) be used for 1000V in conduit once it's transitioned from the PV wire in a rooftop J-box?
Also, I'm aware that fine stranded wire can only be used in terminals rated for fine stranding or else you must use a crimp sleeve. What I can't find is anything clearly defining fine stranding. Is that the Class B numbers in Chap 9 Table 10? More specifically if I'm using #10 (19 strand) PV or RHW-2 wire, can I directly connect it to the lugs on load center circuit breakers?
Does anyone have a suggestion about where to find 1000V UL rated terminals for the rooftop wire transition box? The Allen Bradley 1492-J10 terminals that we normally use carry a 600V UL rating and a 1000V IEC rating. Will inspectors accept the IEC rating?
Thanks,
Jeff Schmidt
Thanks,
Jeff Schmidt
