xguard
- Baton Rouge, LA
I am installing a 6-50 receptacle for a welding machine. The welder comes with the 6-50 plug on the cord. I see in 630.13 a disconnecting means is required in the supply circuit if it is not equipped with a disconnect mounted as an integral part of the welder. The welder has an on/off switch, I don't know if this counts as a discconect, it doesn't sound like it. The supply circuit does have a branch circuit breaker in the breaker panel, can this count as the disconnect? It sounds like it to me but from other threads I read it sounds like others are installing a switch right next to the receptacle or using an integral disconnect/receptacle. I don't see the words "within sight" or "immediately adjacent to" or anything similar. What's the deal?
Thanks
Thanks
