mdshunk
- Right here.
I go for the "EH" boots just to get the non-metallic steel toe. Easier on the tootsies in the winter time.
Non-metalic toes need not be a requirement for EH rating - it does help[ lighten the load though.... Apparently to get the EH rating if I remember this off the top of the head the Meg them (maybe) at 14000V and need to have 3mA or less current measured for 60 seconds - same for steel toed, nonmetalic capped, or non-steel toed versions.mdshunk said:I go for the "EH" boots just to get the non-metallic steel toe. Easier on the tootsies in the winter time.
You might like Doc Martins - the toe box is usualy much wider than other cock-roach killing style - but you may never find some you can try on as I can only find the "Industrial" line - on-line.... Just beware the sizes are UKelectricmanscott said:I have horrendous feet that don't fit into many shoes. These have such a wide toebox and steel toe I can wear regular width comfortably.
electricmanscott said:http://www.timberland.com/sm-mens-endurance-6-inch-titan-xl-safety-toe-brown-nubuck--pi-3012595.html
ramsy said:The description above shows this Timberland Feature:
PowerFit? ..climate control technology to regulate temperature and control moisture buildup and a wider, roomier toe cap that provides a better fit.
OK, fitting the toes is possible, but moister in my Redwing's is killing me, feet itch, gota kick off boots in the car. Scott, are your socks really dry when these Timberland boots come off?
