davedottcom
Is anyone familiar with the NFPA rule for killing lights located under Comm. Kitchen Hoods during a fire?
I just installed a Control panel for an existing hood that had a new section added to it. I hooked all 4 fan motors into the Ansul system and everything is working perfectly...Exhaust fans stay running & Supply fans are "killed" during a fire.
I'm getting different opinions about the lights under the hood being turned off in a "fire" situation. The control panel is set up to keep the lights On (In the new section of hood). but I was told by the installer that the lts. in the old section will have to be turned off!
His reason was because the 1/2" EMT & boxes for the lts. are mounted "under" the hood. The EMT & boxes for the lts. in the new section are mounted on "top" of the hood with only the lights "under" the hood.
Anyone else ever run into this?
Dave
Dave
