Scottie55t
New User
- USA
I'm a bit confused about whether there should be two or three grounds for outdoor antennas. Meaning, some literature online states both the mast and coax cable should be grounded, however other literature also includes a separate ground to the mount as well (so a total of three components are grounds, the mast, mount, and coax cable). Interesting many online diagrams I see online and manuals show mounts and mast, but rarely do I see a ground wire connection to the mounts, just tnear the bottom of the mast and a ground block or llightning arrestor for the coax cable. The both claim to be NEC standard in their diagrams and manuals. S
o my question basically is, should the mount also be grounded with a separate ground wire or is grounding the mount not necessary / redundant as long as the bottom of mast and coax cable is grounded near home entry.
