renosteinke
- NE Arkansas
This topic seems the subject of more double-talk and lawyer-speak than a political convention .... especially on the part of the amulinum wire makers!
I remember, all too well, the heyday of aluminum wire in branch circuits. There was a great deal of pontificating about the high-resistant oxide film forming on aluminum wire, and the absolute need for anti-oxidant when aluminum wire was used.
The IAEI, every month, ran news stories of problems associated with aluminum wire, and the 'lack of proper installation" -meaning inadequate use of anti-oxidant- was the primary excuse given by the aluminum wire makers.
Today we see the aluminum wire makers -again- passing the buck, and saying it's up to the connector manufacturer to recommend it. As in the Southwire link, the makers assert that aluminum needs anti-oxidant no more (or less) than copper. They even state the the routine use of the paste with copper is 'good workmanship.'
Balderdash. NECA standard 104-2006 is a good example. ("Aluminum Building Wire and Cable")
Section 3.2 makes reference to joint compound being used 'where needed to retard oxidation' for any type of wire, including copper. Left out of 3.2 is the assumption, in every other part of the same standard, that joint compound will be used for every other sort of connection.
The same standard includes instructions, with every joining method, to wire brush, coat, connect, and remove excess joint compound.
Oddly enough, such instructions appear only in the aluminum standards. It's certainly absent from the NECA 'good workmanship' standard.
Now, the Achilles' heel of this requirement is that NECA standards are not enforceable as code. Nor, for that matter, is 'good workmanship.'
T&B has a line of marettes (wire nuts) that are CSA approved for aluminum wire, and are used without joint compound.
So, we have a conundrum.
The use of joint compound is a trade practice, with a history of being deemed necessary. Yet, the 'code' position is very weak. While denying any failure of their products, the aluminum wire makers today assert that their wire does not NEED the compound. Testing and approval of connectors, without the use of compound, seems routine.
Absent a specific code citation, I would have to say that the use of compound is not something that can be enforced.
Maybe we need the NEC to specifically address this matter. Proposals, anyone?
