I have a customer that has 320W highbays. The lamps sieze and will not
unscrew. I tried nickle-anti-sieze very lightly on the lamp shell close to
the glass leaving bare metal for good connection and keeping it away from
the tip. It works. The lamps do not fall out but they no longer break in
your hands trying to unscrew them. (You have to Unplug first and wear
Kevlar gloves if they are real bad)Lamps siezing is a big problem in one
building. One of my bosses says stop it is against code the other says it is
not against code.Is it against code? If so where in the code?
