Ron Panunto
Does the NEC require the use of an antioxidant when making connections involving aluminum conductors? If so, please cite the section and paragraph of the NEC that requires it.
Conductor Termination Compound ? Some connectors are shipped pre-filled with conductor termination compound (antioxidant compound). For non-prefilled connectors, conductor termination compound may be used if recommended by the connector manufacturer as preliminary preparation of the conductor. Wire brushing of the conductor may also be performed if recommended. Also see Conductor Termination Compounds (DVYW).
Expert - Definition:Originally posted by Ron Panunto:
The expert hired
