I originally thought my post was a dud, since it did not receive a response right away. But thanks to everyone that has responded.
You asked for a book recommendation, they wrote you one.
No cost e-bookYou asked for a book recommendation, they wrote you one.![]()
This one right here.Don’t know if your experience has been new, ground up construction, but that is one of the best ways to learn troubleshooting. If you know how it was put together to begin with, it makes it a whole lot easier to troubleshoot.
This may be a tough pill to swallow but if your troubleshooting skills are lacking, you really have no business applying for a job that will require a lot of troubleshooting. You'll be very slow, and get stumped too oftenHello all,
I will be applying for a job soon that will require a lot of troubleshooting type work. I have several years experience in residential and light commercial electrical work. My trouble shooting skills are definitely lacking. Can anyone direct me to a online course or possibly a good troubleshooting book? Any information is appreciated.
Occasionally it is as simple as "did you turn it on" or "did you plug it in" or first thing you do is walk up to a GFCI and press the reset button.May I add to all the above:
Learn to break the problem down into manageable 'chunks'.
Example: the light doesn't come on when the switch is 'ON'.
( I guess maybe substituting a known good lamp might be the first step, but anyway....)
Break it as close to half-way as possible, for example, at the load side of the breaker........do you have voltage on the load wire no matter what the position of the switch? stick a known load on it ( 100 W lamp, drill, etc), do you still have voltage ? if so, you have eliminated everything 'upstream' as a possible cause.
Then break the remaining half in half........say at the switch terminals
I think you can all see what I'm trying to say.
Oh, and NEVER go into troubleshooting a problem with a pre-conceived notion of 'what might be wrong'.........trust only what you can see and verify (and don't always trust your meters, etc; more than once 'they' have let me down.......)
Thank you all for your patience
Hello all,
Most of your troubleshooting skills are going to come from doing new construction and payingM attention to methodologies.
Next is remodel wiring, and again paying attention to methodologies. Learning how it was done in various eras helps a lot.
I was fortunate to have worked with some old timers when I first started learning new construction. They taught me stuff I would never have learned from younger electricians.
Also fortunate that after 2 years experience I found a weekend job doing fire jobs. I got to see a lot of older stuff and see it with walls gutted out.
Divide and conquer is good, but if something looks suspicious before even digging into it, that may be the first point to open up even if not in the middle of a chain. You can still sometimes take measurements or whatever and know which way to go next if that point wasn't the problem.Many years ago the electrician that I was a helper to told me to get good at troubleshooting because any one can run conduit and pull heavy wires all day. He told me to divide & conquer. If you had a short on a circuit that had 10 receptacles try to go to middle of circuit and disconnect last 5 receptacles. Some times a VOM meter will not pick up a problem so this works well. Pays to have good quality meters ( 1000 VOLT VOM, Amp meter, and a 1000volt Megger if working on 480 volt motors. A cheap temperature gun until you can afford an IR camera ). I worked on hundred of drives and would call their service department when I could not get the VFD running. Some times it was as easy as changing one of the parameters. Have to be extra careful when jumping out safety devices. Our engineer had my dad jump out all of the safeties on a large boiler while talking to service guy on the phone. My easy going dad at first refused but engineer told him it was okay. Anyway boiler filled with gas then blow out so hard blow off my dad's work shoe. Engineer asked where my dad was. Told him he went down to the bar to settle his nerves. Engineer said but your dad does not drink. Well he drank that day. Some times after hours of troubleshooting best to just walk away for a few minutes go sit down and drink a coffee or a soda and stop thinking about problem. Can not tell you how many times I have done this and within minutes located the problem. Intermittent problems are by far the hardest to troubleshoot. Would have a large piece of equipment that had halve a dozen stop buttons along with a dozen micro switches that could shut it down.
Could be a loose connection or even a micro switch that was slightly out of adjustment. Have to watch genetic prints. You can have 10 pages of prints that show every option under the sun. When I found missing switches, lights, solenoids etc would use a pencil and X that part out.
In fuse panels that have Edison base fuses you could just screw the lamp into the fuse holder.I just posted this in another thread:
Wire a high-wattage incandescent bulb in series with the breaker and the circuit wire. That will act as a current-limiter to allow the breaker to stay on while troubleshooting, and will act as an instantaneous current indicator.
Have a helper watch the light and immediately report any flicker or change in brightness. If you're working alone, you can wire in a receptacle instead, and use an extension cord and a lamp to have the indicator light near you.
and THEN torque the neutrals in the panel. That fixes a lot of the issues I run across!Don’t know if your experience has been new, ground up construction, but that is one of the best ways to learn troubleshooting. If you know how it was put together to begin with, it makes it a whole lot easier to troubleshoot. The journeyman I started out with, had a saying when troubleshooting somebody else’s work, “If I was an idiot electrician, what would I have done?”LOL!
Oh my! Is that a wiggy?Additional tip: Use a solenoid voltage tester, not a voltmeter, when you want to test for the presence of real power, not for a specific voltage. My favorite is the Knopp K60:
I feel like the answer to your question is "that depends. " What type of work do you plan on troubleshooting?Hello all,
Functionally the same. Knopp K-60.Oh my! Is that a wiggy?
Do you mean when you want to just check if the circuit is live?Oh my! Is that a wiggy?
A voltmeter is susceptible to false readings due to capacitance from energized conductors, while a solenoid tester requires enough current to bring down induced voltage. They're also good GFCI testers.Do you mean when you want to just check if the circuit is live?
