JohnE
- Milford, MA
Here's the situation: 100 amp underground service from a pole. 2 Years old. In 2" pvc. 50' pole to building. Lost neutral between pole and meter. Can't pull existing wires out to install new ones apparantly due to ice in conduit.
Any thoughts on thawing?
Any thoughts that broken conductor could be from ice? I pulled this through myself 2 years ago, so I know conductor was not damaged when it was installed. It was backfilled properly, because I was there to see it. I can't imagine what could cause the break in the neutral.
Typically the utility overlaps our riser pipe at the pole with a sort of plastic half conduit and uses some sort of duct seal to keep out water. On this one, they didn't overlap it so it seems water could have been running in. Actually seems lke they used a smaller half conduit since it was 100 amp which wouldn't overlap the 2".
Any thoughts will be appreciated.
