- Massachusetts
tallgirl said:It shouldn't turn to mush.
Once underground AL condutors get wet for a while they do turn to mush.
Dennis Alwon said:This situation brings up two issues for me.
The first is why pull direct burial cable in PVC?
The second is the reason I don't use aluminum. I hate it. I have seen the power co. installed a service lateral and in 2 weeks it has gone bad. I totally agree with the previous post that aluminum with a knick in the insulation is a unwanted destiny. It will go bad and fast.
Copper in conduit cost more but I sleep better at night.
Also many reasons why PVC gets water in it is because most contractors don't prime the joints, as the plumbers always do. I do realize condensation also plays a roll.
iwire said:Once underground AL condutors get wet for a while they do turn to mush.
Also many reasons why PVC gets water in it is because most contractors don't prime the joints, as the plummers always do. I do realize condensation also plays a roll.
Dennis Alwon said:You have just earned electrician of the month for braving the cold and dealing with that. Looks like a mess. I am sure the small 10 gallon shower was no fun either and I bet temps were not above 20 or 30.
Davis9 said:Thats pretty insane! I'm guessing that you were able to salvage the rest of the run here(pipe). How does that triplex pull in on install? I usually use Cu but sometime Al when price is an issue(dealing with multiple bids).
Tom
blue spark said:Good Job! Sometimes you just have to grin and bare:roll: . BTW...-20F through the week up here:smile:
Have you considered using HDPE?blue spark said:Recently we started using 2" flexible carflex as well which seems a better fit for our frost conditions in MN. Frozen 80 will snap like a twig with enough heave pressure.
