Anybody Know What This Is?
That's right. That tiny little thing is a rectifier. I've never seen one in the field before, apparently. I guess I thought they would be bigger, and have some sort of label. This forum's great.
A full wave rectifier. . .the "D" label denotes the DC output. It is bolted to the back plate that will serve as heat sink.
I dunno... the ones I've seen have AC on one pair of diagonals, DC on the other...
I'm with the bridge rectifier crowd. They come smaller and larger. I'm used to symbols for AC in and DC out, not a D on the heat sink extension.
Yep, diode bridge rectifier.
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
The one terminal that is at 90 deg. to all the others is always the + DC terminal, the - DC terminal is always kitty-corner to it, then the other two corners are the AC terminals.That way you can't mess up and put AC in the DC side or vice-versa (if you know that...).
Cast my vote.
Rectifier.
That isn’t what the “D” is for though. That is the labeling for the schematics.
we have lots of them in 115kV breakers.
AC in, DC out, as stated.
Had one CCVT at a station that was a little low on output. Kept blowing out rectifiers.
Ended up putting a small 500VA series XF in to boost the voltage up to about 130V..
I've been into electronics since I was a kid (physically, I mean). I recognized the full-wave bridge rectifier immediately, probably with a 25-amp rating.
Some type of rectifier was my first thought too. I guess you just have to have seen them before. Not sure if anyone could know if it is half wave or full wave just by looking at it, though.
Another clue includes 4 wires/terminals (Although I'm not sure who made them all black - bad planning on the part of whoever assembled this panel, IMO.)
Also, its usually obvious there is both AC and DC in the panel . For example, AC input from a 120V panel, and relays with DC coils). I would normally expect to also see a step down transformer, and either a power supply or at least some filter caps.
Yes, looks to be about that size but I doubt that you'd get rating that unless it is mounted on a heatsink rather than the back panel. The ones we used were IR, usually 26MB120. Shows the chamfer corner.
The wires do have identification ferrules. That's how we did small wiring in our control panels. Black 1.0mm^2 with wires numbered as per the schematic.
