You do have a point regarding the actual switches/dimmers/hardware. We would probably need bayonet sockets or modified GU24 sockets. The incandescent sockets would have to be phased out both because its associated with 120 volts and the fact the shell would be live since our 240 is 2 phases. [/quote.
If you used just 2-wire 240V, wouldn't you earth (ground) one of the conductors?
But if interested on a side note, if a company was to send an Edison base lamp holder to UL today to be approved as new (edisons were not the norm at all) it would fail nearly all criteria. Edison screw bases are actually considered dangerous since one could easily stick a finger inside or over wattage a fixture, however because they are so common the law makes an exception indefinitely on them. In the future we will probably be seeing GU24s gradually phasing out edison screw shells due to the energy requirements but that is another story.
Anyway, back on topic. The only way I could see a conversion taking place is in steps. Newer homes would get both NEMA 5-15 and 6-15 plugs wired via 14/3 home runs to take care of both. Switches would need to be a heavy duty type along with double volt dimmers.
The cost here would be negligible since manufacturers can easily redesign.
Such devices already exist for 230/240V countries so no redesign would be required. It maybe becomes a sourcing exercise.
Older homes would be latter in the step however.
And there you would encounter costs if you went to 240V only. A lot of kit would have to be discarded.
But, in my opinion the biggest set back by far will be DIY. We will be seeing a lot of modifications and internet pages on "how to run 240 volt appliances on 120/120 on 240". First, take a screw driver, then some cord...:happyno:
Yes. Lots of potential problems....
