200614-1422 EDT
mscott52:
First, a relay or contactor are different names for what are basically the same kind of device.
What does the word relay mean?
From Merriam-Webster ---
"5
: the act of passing along (something, such as a message or ball) by stages
also
: one of such stages"
From
www.thefreedictionary.com/relay ---
5. (Mechanical Engineering) an automatic device that controls the setting of a valve,switch, etc, by means of an electric motor, solenoid, or pneumatic mechanism
6. (Electronics)
electronics an electrical device in which a small change in current orvoltage controls the switching on or off of circuits or other devices
7. (Telecommunications)
radio
a. a combination of a receiver and transmitter designed to receive radio signalsand retransmit them, in order to extend their range
b. (
as modifier): a relay station.
vb (
tr)"
Electrical relays come in many forms. Most often you probably think of electro-mechanical relays. These are usually made of a magnetic coil on a ferromagnetic core that can thru magnetic coupling influence the state of an electrically isolated binary electrical switch. You also might want to call a solenoid valve a relay, or a pneumatically actuated valve a relay.
A relay implies something that receives something, and then produces a retransmission of that first said something.
A very simple electromagnetic relay will usually consist of;
(1) A coil of wire wound on an insulating coil form,
This provides electrically conductive isolation of that coil from anything else. This coil is where an input signal is applied to the relay.
The number turns, coil; size, and associated magnetic circuit determine the input characteristics of the relay. The coil specifications determine the ultimate power or current capability of the relay. Only so much amplification can be provided by one relay.
(2) There is some form of mechanically operated switch, usually electrically isolated from anything else, that is magnetically coupled to the input coil. This switch's contact ratings (voltage, current, and breakdown voltage) determines what can be done with the relay output. Whether the output contact(s) is open or closed is determined by the magnetic state of the relay coil.
There is much more. Do your own study. Make measurements. Take a relay apart. Run experiments on different relays.
