Marty Lustig
- Prairie Village, KS
2 1/2" diameter metal gate post mounted in concrete and 5 feet from a permanent pool. NEC calls for grounding/bonding all metal within 6 feet. It will be easy to bond that metal post to the overall pool system ground bus (which does interconnect every other metal item within 6 feet of the water.) NEXT TO the post is the latch side of a metal gate. On hinged side of metal gate is again 2 1/2" metal gate post mounted in concrete. Again I can easy ground/bond it to system ground. MY QUESTION (sorry for the long buiid-up): Can anyone recommend a specific flexible grounding/bonding strap that is listed, UL approved, or otherwise approved for connecting the gate at the hinge side to the non-movable metal pole at the hinged side. I can find many for airplane use and automotive use, but I have not found one specifically for this type of application.
