stuartdmc
- Newport Beach, Irvine, CA
I have a 768 apartment unit complex project that we've just spent 98k on x-raying the Zinsco panels just to find out that 40% to 60% of them are felling the heat testing from over heating from the breakers, main lugs and bussing.
To change out all 768 panels would be unimaginable and costly to say the least, some units only show heat from the load side of the breakers, and others are showing heat at the main lugs and bussing line side of the breakers.
I am thinking about a repair job in lieu of replacement one. My thoughts are, that the apartment complex was built in the 50's, where the Zinsco panels and breakers have had a good 60 year of use, without any maintenance!! I thinking by replacing the breakers with the newer manufactured ones, replacing the bus where there burnt and the main logs if need be I can buy another 60 years. (To complicate the mater even more, they used the first 3 floor of panels as a feed through to feed the panels on the floors above, so to remove the entire panel it would increase the cost to remove the feeders.
I entertain each of your thought for this is going to be an expensive fix either way.
Thanks.
Thanks.
