jaggedben
- Northern California
- Solar and Energy Storage Installer
Just trying to keep my goals realistic.How about joining the crowd that want's 210.12 stricken in it's entirety.
-Hal
-Hal
Why would it matter if it were one outlet or 50 outlets? The idea is to protect the conductors from parallel and series arcs. Exposed live parts (i.e. non-integrated) has nothing to do with it. An exposed live part faulting to the box would be a ground fault, not an arc fault. I think you're pushing 210.12(A)(5) a little too far.
And why would anybody want to do that (AFCI Outlet) instead of a breaker unless you had to?
When breakers won't fit, and client won't upgrade the box, the dirty job of service electricians is properly installing an AFCI outlet when required... much less add an AFCI outlet to home-run switch box for ceiling fans on existing-switched outlets.
That's not just AFCI requirements. That's just people in general in regards to following the code in general.Which is why the ridiculous AFCI requirements are driving that work to not be inspected or done by handymen or other unqualified people.
Nobody in their right mind is going to change to AFCI just because they need to replace their old receptacles.
-Hal
The language is there to provide an alternative method for providing AFCI protection, not an excuse to not have protection at all.Then what do the metallic wiring methods in post 2 have to do with anything? Why is that language there at all?
..Nobody in their right mind is going to change to AFCI just because they need to replace their old receptacles.
Here's the thing, a hardwired luminaire is Utilization Equipment (Art. 100) and the Luminaire (Art. 100) is not part of the Premises Wiring (System) (Art. 100). Therefore, a Luminaire is not part of the Branch Circuit (Art. 100).. . . if I install the hard-wired LED fixture fed via the aforementioned wiring methods, I don't need an arc fault device to protect "the remaining portion of the branch circuit" because there is no remaining portion.
It's mostly because the code is viewed as an over the top, expensive maximum, when in reality, it is a required minimum.
My business policy of leaving "No legal cause for property insurance to void claims" could be an advertising campaign.
It's a bit more complicated than that. You could add income inequality to the equation, price gouging by manufacturers, price gouging by contractors, etc., etc.We are not people in general. When we give a price, for instance, to change out old receptacles or add a ceiling fan and have to explain to the customer that the price is so high because we now have to provide AFCI protection in addition according to code. What do you think the customer is going to do? We don't get the job and some handyman who doesn't know the code or what AFCIs are gets to do it.
This is why 406.4 is so dangerous. It requires added protection for existing or extended circuits and wiring when even minor changes are made that adds significantly to the cost. Customers aren't stupid and don't want to pay for this extra stuff
Upstate here, GC will do it for $30, handiman maybe $20, electrician working by code has to charge just for parts $70. This disparity in part because no universal license or requirements for electrical work be done by electrician in upstate NY. How does one compete like that. We are required ethically and by knowledge to do an installation correctly and code compliant. (At least to the best we can). It is evident by the response in these forums even when discourse becomes "heated" there is an overall desire to have a safe, compliant installation to the best of our ability. We are trying to continue to expand our knowledge of an ever changing field that technology constantly is changing (for better or worse). I can't say that is true for most GCs or handiman, otherwise they would not be deriding proper installation as "thats a stupid rule" and do as they will. While we may may say "that's a stupid rule", we also recognize the code is the code like it or not, but also recognize a proper venue to try to get a stupid rule changed and to get documentation to substantiate a change. That is the difference, that is a professional, that is what we have here, thank you.We are not people in general. When we give a price, for instance, to change out old receptacles or add a ceiling fan and have to explain to the customer that the price is so high because we now have to provide AFCI protection in addition according to code. What do you think the customer is going to do? We don't get the job and some handyman who doesn't know the code or what AFCIs are gets to do it.
This is why 406.4 is so dangerous. It requires added protection for existing or extended circuits and wiring when even minor changes are made that adds significantly to the cost. Customers aren't stupid and don't want to pay for this extra stuff.........
-Hal
I think it's pretty clear that 210.12 is an umbrella requirement for AFCI protection and the subsequent parts are just various ways to provide that protection. You're taking the fact that ONE acceptable method of providing AFCI protection allows for a portion of the circuit to be unprotected as meaning the whole circuit could be unprotected, which clearly flies in the face of 210.12 as a whole.
I would wager the metallic wiring methods premise has to do with having a greater degree of protection of the conductors than say, for example, a drywall screw hitting a cable.
We have already speculated that 210.12(A)(5) is there to provide for a transition period into greater AFCI requirements that deals with (1) the continued use of MWBC's and (2) compatibility issues w/ AFCI breakers and panels.
The only way to know for certain is to find the CMP substantiation associated with 210.12(A)(5) and I don't know how to look that up.
Here's the thing, ...
You also admit that you are basically just speculating as to the intent and rationale. I was hoping someone on this thread might actually have some knowledge about how we got the code language we've got. So far no luck.
False. Many things said here have addressed that. Granted most are guesses, but educated guesses. We've speculated that it has to do with (1) the continued use of MWBCs, (2) breaker and panel compatibility, and (3) a greater degree of conductor protection when installed in metallic wireways.If the intention is an umbrella requirement, then that raises the question of why metallic wiring methods are sufficient to exempt certain portions of the circuit from the requirement. Nothing you've said really addresses that.
Note that I quote you saying " I don't need an arc fault device to protect "the remaining portion of the branch circuit" because there is no remaining portion. " You also suggest in Post #11 that some LED luminaires don't require AFCI even though they are in the areas listed in 210.12.That was a fair number of words to explain something that no one has questioned on this thread.
Plenty of knowledge has been provided. Definitive proof from a CMP, no... but knowledge, yes.
