AFCI and Aluminum Wire?
This is the wrong place for this message, but, I would like some expert opinion of the possible benefit of installing AFCI on a home with Aluminum wiring.
I frequently run into older homes with All aluminum wiring and some with cobbled up aluminum wiring and copper.
Many folks will not correct the aluminum wiring, or will be told, it is only required on and electrical receptacles. Many people only believe what they want because they want the house.
It seems to me that an AFCI would add an additional layer of protection to the unknown sections of the wiring. For example when someone cobbled up sections in the walls or other areas that are not visible, or if the repairs to the aluminum wire corrections were improperly done.
Any thoughts?
