walkerj said:There is only one way to test an arc fault breaker - the test button
AFCI Testers?Not Really
An AFCI indicator may be a nice way to determine if a particular circuit is connected to an AFCI, but it provides no definitive answer on whether an AFCI is properly working or not.
by Jim Pauley, P.E.
If an AFCI indicator plugged into a receptacle protected by an AFCI doesn?t trip the AFCI, does that mean the AFCI protecting the circuit is defective
and should be replaced?
No, an AFCI that does not trip when used with an AFCI indicator does not necessarily mean that the AFCI is defective and needs to be replaced. AFCI indicators on the market today are not AFCI testers, they are listed by UL as AFCI indicators
under one of two product categories including Outlet Circuit Testers (QCYU) located on page 91 of the 2004 White Book or Measuring,
Testing and Signal Generation Equipment (PICQ), which can be located on UL?s Online Certification PICQ at the category code search.
ese AFCI indicators provide an indication if a selected receptacle is protected by an AFCI. ese indicators
are generally used to reduce the number of trips to the panelboard location to push the test button on the AFCI circuit breaker. AFCI indicators
produce a waveform that mimics
an arc and because each AFCI manufacturer has a unique way of detecting an arc, every AFCI indicator
may not trip every AFCI. When in doubt, push the test button on the AFCI circuit breaker to be sure.
Please note the only accepted method for testing an AFCI is to push the ?test? button provided as an integral part of the AFCI itself.
AFCI indicators are provided with instructions that state the proper way to ?test? an AFCI breaker.
AFCI indicators are required to be marked on the product or provided
in the user instructions as follows:
?CAUTION: AFCIs recognize characteristics unique to arcing, and AFCI indicators produce characteristics
that mimic some forms of arcing. Because of this the indicator may give a false indication that the AFCI is not functioning properly. If this occurs, recheck
the operation of the AFCI using the test and reset buttons. e AFCI button test function will demonstrate proper operation.?
gojoeba said:Anyone have a problem with Murray Arc fault breakers not passing the inspectors test when using an Ideal plug in arc fault checker?
wptski said:FLA:
This has come up before here and results are always the same. Most all in this forum believe the "only" true way to test a GFCI/AFCI is to use the TEST button, if that works, it's good.
What "facts" do you know about a AFCI TEST button that leads you state that? Exactly what does the TEST button do??electricmanscott said:And the facts back us up.
Brilliant!electricmanscott said:And the facts back us up.
Post # 8 is good enough for me.wptski said:What "facts" do you know about a AFCI TEST button that leads you state that? Exactly what does the TEST button do??
ELA said:Brilliant!
That doesn't say squat about what the the TEST button does. If you don't rely on a CB switch, why in the world would you rely on a TEST button?:-?electricmanscott said:Post # 8 is good enough for me.
http://www.squared.com/us/applications/residential.nsf/LookupFiles/RetailinkApril2005.pdf/$file/RetailinkApril2005.pdfUL Affirms AFCI Test Button As Only Method to Test AFCI Breaker
Underwriters Laboratories (UL) has recently written a concise letter which explains that AFCI indicators do not test AFCI circuit breakers. Instead, they simulate an arc in an attempt to trip them also noting that AFCI indicators may not trip all AFCI devices. UL has affirmed only the ?Test? button should be used for proper testing of the AFCI circuit breaker.
The letter is posted on the UL website at:
http://www.ul.com/regulators/afci/index.cfm
to share with those that may benefit from further information on the AFCI indicator.
UL will also e-mail the letter to a few thousand inspectors and publish it in a UL Code Authority mailing to nearly 12,000 inspectors and others in the industry.
http://www.jupiter.fl.us/buildingdivision/upload/AFCI-Testers-and-UL-Letter.pdfAFCI TESTERS & UL COMMENTS
Thursday June 12, 2008
Attached is a letter, dated March 21, 2005, from UL in regards to AFCI testers.
Many individuals previously purchased AFCI testers only to find that even though UL listed some of them they were not recognized as legitimate AFCI testers.
Many functional Branch Circuit AFCI breakers appeared to fail the test because the tester would not trip the AFCI.
Now that the Combination AFCI's are out, we are hearing that many individuals using these same testers, are failing "good" AFCI's because the AFCI tester will not trip the AFCI.
Apparently these AFCI testers will trip the new Combination type AFCI, even less frequently than the old Branch Circuit type of AFCI.
In the attached letter from UL it is noted that the only recognized test method is to push the test button that is provided as an integral part of the AFCI.
If the AFCI does not trip then the AFCI is defective and must be replaced
wptski said:That doesn't say squat about what the the TEST button does. If you don't rely on a CB switch, why in the world would you rely on a TEST button?:-?
Just from what anybody can read, a AFCI is supposed to trip under several conditions, maybe more, who knows right now. Do you think that a AFCI can monitor all those conditions and its TEST button will simulate all those conditions too?? Do all that for the price they are selling at now?
A GFCI is simpler, where a condition can be simulated easier with a TEST button.
